An expert is just a guy who was lucky enough to live through all his mistakes.
That's a great saying. I am not an expert and I don't play one on the internet. And I have been very lucky to live through all of my many mistakes thus far.
We have access to a 60ft spiderlift through a friend, so that's the size of lift that we were using. No, it was not ideal for this particular tree by any means, but it was still safer than climbing. This tree was sketchbag. This is one of the biggest cemeteries in the city, and they let stuff go way, way too long. But at the same time, they are our biggest client, so I couldn't just pass on the work. Yes, at the point that I had to make that final cut, I was way too invested to just pack it in and tell the guys that we would have to figure something else out. The area of the cemetery that we were working in was not soft ground by any means, there were no fresh graves. The ground was very solid. Soft ground is very scary with these new spiderlifts, definitely something to consider when setting them up.
As far as the rigging is concerned, as a concept, I have always split the load between at least two spars. This concept however makes far more sense when the spars in question are at roughly 45 degree angles, so that they load in compression. The leader that broke in this case was basically vertical, which meant that it was being side-loaded. I should have been much more critical of that spar and done a much more thorough inspection before rigging off of it, but it had been supporting a live crown, so I figured it would be ok.
For my first 3 years, I used natural crotch rigging almost exclusively, and yes, it makes more sense in a ton of situations. In this case where I was using pulleys, NOT splitting the load would actually have been much safer.
Like most accidents, it was not just down to one single error, there were a whole bunch of things that I did wrong that compounded to produce that result. What I didn't explain very well at all in the video is that, in the moment, the thing that I was actually the most concerned about was that big hanger, which completely blinded me to the actual danger staring me in the face...
