pantheraba
More biners!!!
I got a request for a bid yesterday from the neighbor where I did 2 trees last month. These 2 oaks, one on each side of a storage bldg. are declining and the owner wants them removed. I should be able to flop the one that is "part of the building" with a top rope and wedges. It can go straight away from the building into a wooded lot with good openings to throw it.
I plan to bid $300 to do that...may include cutting it up, too...the owner only wants the trees down, he does clean-up.
The other tree has targets everywhere...everything will have to be roped, with at least 2 or more cuts for each limb...they are long and pretty large. I figure to use fishpole system with 2 blocks for most everything. I want to spread out the force on the blocks since some of the wood may be compromised.
He has some 1/4" hardboard (like thin plywood) around which I hope to be able to put on the roof of the storage unit to protect it from deadfall/breakoff.
I figure I need to bid at least $1800 to remove the one tree that has to be rigged down...maybe more? It will probably take me 2 days to do it.
What would you bid?
What would you bid?
