MasterBlaster
Administrator Emeritus
Are they safe to work off of, or they meant only for tending your rope/hitch? I'm thinking the latter. I wanna get a pulley for pulling myself up a tree and I'd like the smallest possible.
is a friction saver smother than a pulley?friction saver is better..............
It takes two ropes. Tie a carabiner to the end of Line 1, clip pulley to 'biner, set your climbing line in the pulley, then use Line 1 to haul up the climbing line.OK so how do you get that pulley up and back....I aint taking no rope guide thingy...............Your exaggeratting a bit there Carl...
this is the way i do it.If you are going to set a pulley on a sling, feed your climb line through it, come down, and then use it to pull yourself up again, then the pulley will work o.k.
Just remember that once you set that pulley, you MUST go back up and get it.
The ring and ring friction/cambium savers are much much nicer to climb on. But, I seem to get them stuck on retrievels all the time.
