I think lumberjack has it exactly right. But even if a loose braid would get you close (it would), you have a much trickier problem trying to attach your "rope" to anything in such a way that you don't take one of the little ropes right out of the equation. With a very stiff rope like Black Widow, a small lack of symmetry in the attachment could mean one of the little ropes is slack even when the other two are under heavy load. The slack rope would not start to share the load until the other two have stretched enough to cover the slack. With much stretchier rope, the same exact scenario has a much better result. The two loaded ropes have to stretch the same distance to remove the slack, but much less force is required to stretch them. The inequality in load sharing would thus be much less. Whew!
