bonner1040
Nick from Ohio
VIDEO:
http://youtu.be/qamzqQkxsqI
So we made an air cannon. The only power source is a standard bicycle pump or any random compressor or similar air source. See a rough drawing here:
The first build was PVC which was definitely a mistake. It exploded @ 60psi twice. The second build is all steel and much sleeker. So far we have been using 12 and 16 ounce Weaver weights and the 16 works best. Easily launches either weight over 200'. By decreasing the PSI you can control and aim with remarkable accuracy and repeatability. It stands a little over 6 feet assembled and the end easily pivots on the ground for aiming and recoil free firing.
The build was really easy:
Assemble pieces as in drawing using teflon tape and pipe wrenches.
The ball valve should have handle @ 90 degrees to tube for “closed/armed”. My experience is that it works best when the “trigger” mechanism is to pull the handle towards the user.
1. Set valve to “closed/armed”
2. attach pump to sniffer valve (located on T fitting)
3. Load throwball attached to throwline of choice. (it will take some rolling and mabe a stick to jam it in there. A good fit is best.
4. Pump to between 40 and 100 psi depending on weight and height.
5. Aim . Fire. Awesome huh?
