flushcut
Vertex Vent for me with Husqy muffs and mesh.
I know you don't want to spend the money but the Protos truly is the answer you are looking for. Built in muffs and face screen, lightweight, vented, and very comfortable. I had a Petzl prior and there is no comparison.Do you use the Husky face mask with the muffs? That's my intention with mine eventually. I have the one made for the Vertex, but it's wearing out, and I'm not super fond of the new Vertex mounting system. It's kind of fiddly, and doesn't always properly lock in place. I have a Husky forestry helmet, but I used the muffs on one of my Vertexes, and it looks like the faceshield will work well enough. I use that for ground stuff, and the plastic visor in-tree. I find the big shields get caught up too much in branches. What I'd really like is a low profile visor made with screening instead of plastic. That would be the best of both worlds, cause the plastic is hot. I have to raise/lower that, or else it'll be covered in fog/sweat in minutes.
It has a really interesting method for installation and, in order to retrieve it, you must (at some point, before you descend to the ground and finish your climb) ascend to where the pulley saver is and clip that little accessory/retrievable carabiner onto the correct strand. If you don't do that, then you won't be able to retrieve it and you'll need to climb all the way back up to your TIP and clip the little 'biner on.Looks cool. I'm having problems with brainlock understanding how it's set and retrieved. I guess I'll have to wait for your video :^)
No pelter on there apparently?Short answer is, yes. Partstree.com is were you can order all the Husqy muff and screen parts individually. Hygiene kits for the muffs and whatnot.
that is not a very good setup, the eye is still to supple and therefore you will experience difficulties retrieving it. also the bowline will likely catch on stuff. the carabiner used to connect the pulley to the hitchcord is slightly frightening. a better setup would be a endless loop tied with two opposing double-fishermen (you need a pinto-spacer)Even though I only climb MRS roughly 20% of the time when I climb a tree, I am still obsessed with learning all about techniques, and how to use gear for, moving rope systems. I work very hard to stay up to date with every aspect of tree climbing. I do this mainly because I have a vicious tree climbing obsession, but also because I enjoy making videos about MRS for my YouTube channel in order to attract people who climb that way, and so that my channel is eclectic as possible (I want my channel to have a ton of variety).
I recently became very interested in pulleysavers, rather spontaneously, because I've noticed that there isn't a lot of content out there which covers these alternatives to a ring to ring friction saver. After only 15 minutes of online window shopping, it quickly became abundantly clear to me that buying a pulleysaver was going to be out of the question. They cost hundreds of dollars and there aren't a lot of options to choose from either.
So, in true Knotorious fashion, I decided right then and there that I would make my own pulleysaver, and I would use this opportunity to make a video all about how to make your own pulleysaver. Once completed, I decided I would then create an in depth video showing the two main ways to use a pulleysaver; as a low friction TIP in the canopy and as a spar anchor. I also decided I would demonstrate how to install one from the ground and how to retrieve one, wheter from in the canopy or from off of a spar.
Long story short, I accomplished ALL of these goals in 48 hours. The videos turned out amazing. I finished editing the demo video, but I still have to edit the video where I show how to make an adjustable pulleysaver; which I'll do once I finish this post.
The pulleysaver I built is made using a 12mm bull rope that began at 16 feet long. I tied a Scott's Locked bowline on one end of the rope (because bowlines tend to result in a loop that stays pretty round), then I used a 32" spliced 9mm Sterling RIT eye to eye to tie a six coil prusik, clipped a DMM Perfecto onto it, then attached my DMM Pinto pulley to it. For the retrievable component, I tied a six coil prusik using a loop of 6mm accessory cord, which was made by melting both end of a straight piece until they were goopy and then pushed the ends together, using pliers to compress everything into a tidy, round fusion. I then used a DMM XSRE with a screw gate and, in order to ensure that my throw ball would pass through my pinto, but get caught on the XSRE, I wrapped the entire perimeter of the XSRE with 1mm paracord.
All of the pulleysavers available for purchase online (as far as what I, personally, have seen for sale) have pulleys that are permanently connected to sewn loops for forming the six coil prusik for adjustability. This means that you can attach your rope midline.
I used an eye to eye because a) a tied loop using a double fisherman bend would result in a huge, bulky knot that could get stuck on something and b) it allows me to connect my pulley via a Perfecto carabiner, which means I can install my rope midline. My pulleysaver was not only super easy to install (it worked beautifully), but it was just as easy to uninstall using either a soft or hard retrieval.
What's great is that this pulley saver cost me a grand total of ZERO DOLLARS. Additionally, I can quickly take it apart and use any of its components for other applications and, should I ever need my pulleysaver again, I can easily reassemble it in under ten minutes.
Attached are some pictures of the pulleysaver I made! If you've never used a pulleysaver for a spar anchor before, than you're missing out big time. Not only is it much lower friction than a ring to ring, but it locks onto the tree in a choking configuration, versus the ring to ring which is in basket configuration and can often be a pain in the ass to keep from slipping down a spar; especially if it has smooth bark.
Also, I bought another DMM Perfecto, but this one has a removable captive bar, which is going to be perfect for permanently installing it onto my Rope Runner Pro! In the picture, I've placed a regularly sized carabiner (Petzl OK Triact) next to it for perspective.
Conclusion: You wouldn't catch me dead paying hundreds of dollars for something that I can make on my own. My two videos came out absolutely phenomenal and I'm extremely proud of my work.
View attachment 138637View attachment 138638View attachment 138639View attachment 138640View attachment 138641View attachment 138642View attachment 138643
