Spur Length
  • Thread starter Thread starter HBP
  • Replies Replies 55
  • Views Views 6K
HBP
Northeast Ohio
What do you guys prefer and for what reason. I assume most of the west coast climbers prefer longer gaffs. A lot of guys I work with prefer shorter pole gaffs for most of the hardwoods we climb in my area. I can see the advantages to the short gaffs, able to walk around without dulling them, more foot to tree contact for stability. But it seems like they have a tough time climbing trees with hard, or plated bark. I wear long gaffs because i like the security of kicking them through the bark and into the wood. What are your opinions? is there a perfect length for guys in the midwest/northeast?
I used to swear by long gaffs, but I got tired of tip-toeing when I was on the ground. Plus, other than cottonwoods, we just don't have such thick barked trees around here. So, I use pole gaffs. Ideally, having two sets would be best and I did at one time - but I wound up selling them to Burnham cuz I just never used them.
I use long ones for most of the work, if I have to work in thin tops of smooth barked trees like birch, I don the short ones.
I machined some gaffs years ago that are mid-length between pole and tree gaffs and they work great in nearly every situation I run into. Does any manufacturer make anything similar, and if not, why not? It looks like there would definitely be a niche in the market for them.
  • #10
I was kinda thinking the same thing.
I use the Long gaffs for pruning bradford pears...:big-rolling:
On a serious note, I use long gaffs here in nor cal, lots thick bark tree's
I use short gaffs.
I bought my spurs as a set with both short and long gaffs, but I never mounted the long ones.
Hard wood or soft wood, they don't have a really thick bark. Some have deeply (for me) cracked bark though, but I can overcome that with a little attention.
The main problem that I encounter time to time is trees covered with a thick layer of ivy.
I like shorties myself. Most of the trees I work on have thin bark, and I'm light enough that even in thicker barked trees the bark itself will usually support my weight reliably. The one exception is Melaleuca trees, although I think they pretty much suck with even the longer spikes.
Long as I can find...
Ditto! I realize that thin-barked trees can be efficiently climbed with pole gaffs but as with my climbing line, I would rather have a little too much than not enough. Thin barked trees are just as easy, at least for me, to climb with the longer tree gaffs. Pole gaffs are optimized for poles and tree gaffs for trees, that is the reason for their names. How easy it is to walk around on the ground with my spurs on is not high on my list of appropriate attributes.
David
