Copier/Printer/Scanner Advice.
MasterBlaster
Administrator Emeritus
Louisiana!
I need a new one, any thoughts? I've heard there's one brand that installs a lotta spyware/malware/ect... (maybe it was Hewlitt Pacard?) It doesn't have to have a fax, just the other stuff.
Peter
East Angular
I have a Brother DCP 7010 laser psc, great if you dont need colour, as one toner will last around 2000 pages.
Che
Central Kentucky
I've been happy with HP printers.
The only Scanner I've ever had is the one I'm using now....an HP scanjet 3570c, no complaints.
M
Mr. Sir
I've got the Dell All-In-One model 964. No problems here. It came with the system for only $99, but I have to buy cartridges from Dell exclusively and that adds up over time if you do a lot of printing. I could probably save some money and go to Walgreens or CVS to get the cartridges reloaded, but I've never done that.
My wife has the HP C4250 All-In-One and it works fine too. $99 from Sam's Club and ink cartridges are available anywhere.
B
Blinky
I've been using a Brother 4100 for about five years now, still works fine. I like HP's professional grade hardware but you would do well to do a 'driver only' install and skip all the little doo-dad software that comes with it.
N
NeTree
I have a Lexmark; it works great, but the cartridges are pricey. I wouldn't buy it again.
stehansen
Climbing Up
Ceres, CA
I have an HP 6180 all in one and it works good but everytime you turn around it needs a $30 ink cartridge and walgreens won't fill them.
CurSedVoyce
California Hillbilly
Near Yosemite in CA USA
Old HP 4P.. Cheap as heck for your black and white needs.. 1500-3000 copies per cartridge. Runs me about 35 bucks with shipping if I dont go through HP. Color copying... we have a few of them. But this rocks on B&W... What more do I need for the office.
BTW MB you can often find them used on line for about 150.00 for a reconditioned. They have a serious following.. Runs like a plug in on XP.
CurSedVoyce
I use mine daily, Kids too. I am on my 3rd ream of paper and no signs of degradation on my print. Crisp. It is just old fashioned toner tech. Just like a copier.
BTW ... I can service it myself with a phillips head screwdriver and a cotton swab. I had it in storage for 5 years... Put a new catridge in it after a lil cleaning and she fired right up... These things sold for over a grand new.... figure....
Reddog
Great Lakes state
We have a new Dell V305. But I have not used it enough to find the faults in it. The one thing that could add up is the dell only ink.
CurSedVoyce
Thats why I stay toner for the B&W. I have a few color and fax and ... But for the every day printing.. I go with the toner... Great quality cheap.. Let that do my bulk.
cybergeek23851
I like cats...
Cedar Rapids, IA
Mine WORKED great until Monday night when the printer itself died. I was tired of inkjet cartridges also drying up in a month, so I went with a laser... a color laser.
I picked up a kick-@ssed Samsung color laser for $150.00, Monday night. I still have the old scanner to scan stuff.
http://www.officemax.com/omax/catalog/sku.jsp?skuId=21658332&searchString=&category_Id=364
SkwerI
central Florida
They all use ink, just different technology for applying the ink to the page. And it doesn't scan unless it says that it's a scanner.
SkwerI
central Florida
What are your printing needs? I don't print much so I'm fine with the cheap printers. My current is a Lexmark P915 that can print photo quality. Ink is pricey but I don't use it much and the printer cost $120. No scanner, but I've probably only needed a scanner 4-5 times in the last 5 years.
B
Blinky
lasers use toner and fuse it to the paper, it won't run or fade if it gets old or wet. Inkjets use liquid ink that dries on the paper, most of it is water soluable and it fades somewhat over time.
Some lasers use a toner cartridge with a built in imaging drum (more expensive cartridge), some keep the drum separate(less expensive cartridge). The drum has to be replaced every so often so it can be an additional maintenance expense.
Cheaper (in price) lasers generally have the built in drum type of cartridge.
Most inkjets are designed as disposable technology. Stuff goes wrong with the heads or the waste ink reservoir gets full and you toss it for a new one. They work well as long as you use them regularly. Not necessarily a lot, just enough to keep the heads from drying out and clogging.
