Peter
I have a hydraulic power pack to wire up to a 12v vehicle system.
The motor is rated at 1.8kw, which at 12 volts needs a 150 amp supply?
The power pack runs a tipper unit, so it will be run for 30 seconds at a time, and not too often.
What cable size should I be using, the online calculators I have tried say 50mm2, which seems a little on the large side. I am wondering if a low duty cycle means I can get away with a smaller cable.
At the moment I have a 70 amp fuse and 4.5mm2 cable, which is probably a little undersized but is all I had to wire it up at the time. It blew a 60 amp fuse, so I upgraded to the 70.
Thanks
Thanks
