What are you climbing typically, species, size, obstacles? for what kinds of work?
With a good, high tie in point, you can get way out on tips that you wouldn't otherwise be able to get to so easily by dropping through crotches. Say if you had to cut way out near a house away from the main TIP, you could ascend to the high TIP and set if you want to, you can arrange one line for re-accessing and one to do the work. Go out for one work quadrant, and drop through crotches, do your work, lower down to the ground and come back to the base, ropewalk up or otherwise ascend, do another quadrant, and pull both ropes from the ground. If it easier, you can climb back through crotches and redescend to get to other work areas in the tree.
Understanding force vectors (Using compressional forces on limbs by going through crotches rather than pulling more in shear, somewhat sideways on a limb/ crotch) allows you to work out on smaller wood without all the redirects and friction of two parts of rope going opposite directions through a crotch or biner or double biners attached to one redirection sling.
Fighting friction is highly reduced. Having to protect the tree against friction is greatly eliminated (if need be, you can use leather or fancy cambium savers or just tubular webbing. Isolating a line is reduced/ eliminated. Ground lowering rescue is an easier option.
If you need to change over to DdRT, you don't need to get the WR off the line, just unclip the tether to keep it from getting engaged.
