vise mounted on chipper fender.
  • Thread starter Thread starter stehansen
  • Replies Replies 29
  • Views Views 6K
stehansen
Climbing Up
Ceres, CA
I mounted a vise on my chipper fender today. I haven't used it yet, but I'm wondering if there is a better place and what you all do. My contract climber guy says that I don't need one, that a vise is a crutch. I say BS, if it makes it easier to sharpen a saw then what's the problem. I've seen Butch's setup in the back of his pickup. I have another one of these small vises that I might want to set up also.
Looks good! Now just mount an umbrella there behind it and you're all set. :D
I put a vise on my truck last month. I've missed the one I had on the old truck. It was in a custom bracket that fit into the receiver hitch on the back of the truck. My current truck does not have a receiver hitch so I mounted it up on top of a toolbox. I have to step up into the bed of the truck to use it but it was the best location I had available on this truck. I'll see if I can remember to get pictures tomorrow.
In the meantime, here's a pic of the old setup. I'm not sure if Justin is still using it or if he ditched it.
I hope you put panhead bolts up thru the fender so the tire doesn't hit the nut and excess threads (if they are hanging down)
Best thing I ever did, makes sharpening and misc fix's a breeze on job site. You can see mine on my toolbox in this pic.
Nothing wrong with where you put the vise. I see many chippers with vises mounted on them in the same place as yours. I was always going to that to my old chipper as that is where I would do the saw sharpening. All I needed was a place to keep the bar from moving around. For small to med sized saws it was ok but a bar longer than 24 inches became a challenge.
With the new to me chipper I now sharpen saws on the chute. Darn thing is so big and wide you could lay down and take a nap in there. If we are on a job with no shade we have gotten out of sun by sitting in the chute during break times.
I always put that job off of drilling holes in the fender because it would be a good place for rust to get started. When the time came to sell it those holes would be there if you took the vise off. This is just me though. I think you did a good thing and if it makes it easier for you to sharpen a saw so much the better.
Im thinking of puting one on mine I think it would be better and safer if it is in the ruight side to keep us out of the street
  • #14
It has regular hex bolt heads down in the fender and I put the threads up and double nutted them.
  • #15
That would be better. My right side fender is covered up with the feed roller housing. Mine is probably on the low side. I can always raise it up if it is a problem. Being out in the street is a disadvantage.
I like Brendov idea. I am 6' 4" looks like a good height and an extra tool box is always a good thing.
i dont use a vice but ive thought of putting one on there for the crew or other misc tasks
Mine came in handy last year when I had a hydraulic hose break on a Sunday job. Luckily the hose had a reuseable fitting, so I was able to remove it, cut the end of the hose and put the fitting back on. I wouldn't have been able to do that without that vise.
  • #19
I thought it would come in handy for general stuff also Brian. I checked out the height and I think I am OK. It's about bellybutton height.
Brian, I'm using it and loving it. After twenty plus years of sharpening on tailgates and stumps (and getting pretty good at it) I have discovered that I can do better, faster using the vise.
Now that right there is a great idea .The vise plus the reusable fitting .It might not be a bad idea to pick up a few of various sizes just for such an occasion . Those hose ends have the tendency to blow apart at the most inopertune times and locations .
I once blow the end off the "stinger " cylinder hose on a line truck .Because of the pilot operated check valves I could not lower the boom all the way .I must have blown 10 gallons of fluid trying . Talk about a pain in the butt driving that thing about 10 miles to the shop with the boom about 1/3 of the way up weaving around traffic signals so as not to snag one ,jeez .:(
