PCTREE
OK heres a silly little idea I had thought you guys could ridicule. Ok so Im sure we all do it and know we shouldnt. You know the too dead tree that you worry will fall over with you in it so you tie in to something else as a back up. As you are working the dead tree it occurs to you that if the tree fails you couldnt release your lanyard as it would be under tension. OK so heres my solution ( this might not be OSHA approved)
I need to remove the matal ring on the snap bail and put a piece of string in its place so its easier to pull.
Fire away
Fire away
