No, but I've been making my own for several years. Mine are 24"x24" because that's how big the storage slots are on the sides of my truck. I started with four 2x12 lumber cut 2' long and nailed together but they weren't holding up very long. About 2 years ago I began making them out of plywood and they have held up much better. To make two pads I use one sheet of plywood (either 5/8" or pressure treated 1/2"), construction adhesive, fence/deck stain (to seal the plywood before assembly), some deck screws and a piece of scrap tubular webbing for the handle.
Cut your plywood squares and paint them, especially the edges.
Glue them and stack them. I notch one of the inside squares so I can insert the knotted ends of the handle strap during assembly. The handles will never come out.
Clamp them together tightly. Run some deck screws in them to help hold them together. Grind off the ends of the screws if they poke through the bottom.
The next day unclamp them and they are good to go. I'm getting about a year and a half to two years out of them.
