Windsor speed tip
  • Thread starter Thread starter Al Smith
  • Replies Replies 12
  • Views Views 2K
Al Smith
Mac Daddy
Northern Ohio
Windsor I think made the original replacable bar tip and I believe it's this three rivet model .They made bars for just about every make of saw at one time and especially McCulloch .
This 32" bar was given to me and was odd indeed as it is a 50 thou groove bar but had a .404 nose on it ,10 series mount .I assume it was a PNW bar because that size was never used in these parts .
Not to worry 17 bucks for a new nose and back in business with a 3/8" nose and 105 links of Oregon 72 round chisel skip chain .They get about 150 for a NOS Mac bar like this on flea bay .
Nothing to changing a nose .Drill out the three rivets with a 5/32" drill ,punch out the rivets .Install the new nose ,pound the rivets flat with a hammer .No need to actually peen because they are counter sunk .Took about twice as long to do as for me to type it .
Sorry about the blurring pics the lens had some stuff on it .
You put that on the 805?
I knew a guy out west that had a lot of 404 050 chain.
Yeah on the 805 . I assume it must have been a deal maybe 25-30 years ago on those medium sized Douglas fir trees .Using the wider kerf .404 chain so it chipped out better .
I imagine since for example McCulloch circled the drain in 98 and the 805 was just about the last professional saw they made it was probabley 5 years before then they lost favor as a pro feller ,maybe even more years before .
About the only .404 by 50 thou you can find is on flea bay .
I hated to see Windsor go out. I liked them as they were a little narrower than Oregons and several dollars cheaper.
That tip came from an e-bay seller that sold several styles of replacement tips ,Windsor,Oregon couple more .I've got a 36" Windsor ,Stihl 066 style adapted to fit the Homelite in my avatar .
Willard, do you see any advantage or disadvantage with the thinner drivers on that chain? Get a little increased chain speed from it? It doesn't seem like they would break..or maybe slightly susceptible where the rivet goes through?
For years up until a few yrs ago I used up about 40 feet of this chain on my 066 Stihl -28". Good tough chain, very little stretch holds a good edge and lasts alot longer then the 3/8". I round filed it of course seeing I'm using it for arb ground work and never broke a link.
I don't fully understand the .050 logic in a .404 chain. This roll did come from the PNW and seeing the timber they used to cut out there I guess every advantage in friction reduction etc. counts. Even the .058 .404 is gone now.
Yeah, I was going to say that I thought that .063 was standard with .404. I know that they have started putting out .404 with the cutters on a lighter chassis that usual, as of a few years ago, so probably thinking about chain speed, which I guess you mean by friction.
