Hydraulic powr pack ?
brendonv
Tree Hugger
Oxford, Connecticut
Putting together a hydro power pack.
13 hp honda, 3600 rpm, equipment requirements are 7 gpm, and 2400 psi.
From my calculations ill need about a .50 cu in pump. How/where can i find the right pump with the right gpm, and psi?
Ive found a bunch but get lost when they say things like conti. or int. psi. Rated and max, etc.
Conti means continuous i.e. it can provide that pressure all day long int or intermittent it can produce that pressure but only for a short duration so if you need 4000psi all day long and said pump can provide 4000 int it won't work
