Greenteeth types...Red Vs. Green Vs. Wearsharp
  • Replies Replies 1
  • Views Views 2K
SeanKroll
Olympia, WA
Greenteeth® LoPro Stump Cutters
Increased tooth diameter and reduced pocket thickness allow for a 3/4" clearance between the side of the pocket and the stump. This prevents the pocket from rubbing against the stump, which significantly reduces pocket wear and improves overall performance of your stump cutter.
Wearsharp
The Wearsharp tooth maintains a sharp edge as the tooth wears in use, for optimum performance.
Green vs Red
You have the choice of "green" or "red" cutters. Standard or "Green" teeth have a shallower profile, making them more durable, especially when in rocky soil. The Deep Dish or "Red" teeth have a deeper profile, for a more aggressive cut - not recommended for rocky soils (25% or more rock).
The LoPro design is available in three series: 500, 700, and 900.
500-series: for machines 16hp and smaller. Diameter is just over 1/2".
700-series: for machines with 18 to 35hp. 3/4" diameter.
900-series: for machines with 35 to 65hp. 7/8" diameter.*
*900-series tooth performs exceptionally well in tough conditions.
How do the Wearsharp perform compared to Green or Red?
