Cobleskill
Bio-Diesel at 2% is #1? Sounds like the way to go for the older stuff not designed for low sulfur.
Ads by Google
Diesel Fuel Additive
Diesel Turbos
Cummins Diesel
GMC Duramax Diesel
Diesel Engine
Home Forum Market Place Garage Live Chat Tuning Library Register Vendors
Go Back Diesel Place > GM Trucks > Maintenance & Fluids
Reload this Page Lubricity Additive Study Results
User Name SAVE
Password
Register Showroom
Showroom
Showrooms
Browse by Username
Browse Recently Added
Browse Recently Modified
Browse Most Popular
Advanced Search
Help
FAQ Forum Rules Calendar My Replies My Threads
Live Chat
Enter Live Chat
Enter Live Chat (Float)
Who's Chatting?
Go to Page...
DieselPlace.com is the premier Duramax Diesel Forum on the internet. Registered Users do not see the above ads.
Closed Thread
Page 1 of 14 1 2 3 4 5 6 7 8 11 > Last »
Thread Tools
Old 08-26-2007, 02:41 AM #1
SPICER
Diesel Fanatic
View Photos By: SPICER
iTrader Score: 0 reviews
The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time.
PURPOSE:
The purpose of this research was to determine the ability of multiple diesel fuel additives to replace the vital lubricity component in ULSD (Ultra Low Sulfer Diesel) fuel.
HISTORY:
ULSD fuel is the fuel currently mandated for use in all on road diesel engines. This fuel burns cleaner and is less polluting than it’s predecessor, called Low Sulfer Diesel Fuel. Low sulfer fuel contained less than 500 ppm of sulfer. ULSD contains 15 ppm or less.
As diesel fuel is further refined to remove the polluting sulfer, it is inadvertently stripped of its lubricating properties. This vital lubrication is a necessary component of the diesel fuel as it prevents wear in the fuel delivery system. Specifically, it lubricates pumps, high pressure pumps and injectors. Traditional Low sulfer diesel fuel typically contained enough lubricating ability to suffice the needs of these vital components. ULSD fuel, on the other hand, is considered to be very “dry” and incapable of lubricating vital fuel delivery components. As a result, these components are at risk of premature and even catastrophic failure when ULSD fuel is introduced to the system. As a result, all oil companies producing ULSD fuel must replace the lost lubricity with additives. All ULSD fuel purchased at retail fuel stations SHOULD be adequately treated with additives to replace this lost lubricity. The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems. For this reason it may be prudent to use an after market diesel fuel additive to ENSURE adequate lubrication of the fuel delivery system. Additionally, many additives can offer added benefits such as cetane improver, and water separators or emulsifiers.
CONTENT:
In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity. Additionally, claims of improving cetane, water separation or emulsification, bio-diesel compatibility and alcohol content will be noted. These notes were derived from information that was readily available to consumers (via the label and internet information) and none of this information has been evaluated for validity and/or performance. Cetane information has only been noted if the word “cetane” was used in the advertising information. The words “improves power” has not been translated to mean “improves cetane” in this evaluation. Information on alcohol content is provided by indicating “contains no alcohol”. Omission of the words “contains no alcohol” does not imply that it does contain alcohol. This information was simply missing in the information available to a consumer. However, the possibility of a form of alcohol in these products is possible. Additionally, information on dosages and cost per tankful are included for comparison purposes.
How Diesel Fuel Is Evaluated For Lubricating Ability:
Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar.
The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better.
METHOD:
An independent research firm in Texas was hired to do the laboratory work. The cost of the research was paid for voluntarily by the participating additive manufacturers. Declining to participate and pay for the research were the following companies: Amsoil and Power Service. Because these are popular products it was determined that they needed to be included in the study. These products were tested using funds collected by diesel enthusiasts at “dieselplace.com”. Additionally, unconventional additives such as 2-cycle oil and used motor oil were tested for their abilities to aid in diesel fuel lubricity. These were also paid for by members of “dieselplace.com”.
The study was conducted in the following manner:
-The Research firm obtained a quantity of “untreated” ULSD fuel from a supplier. This fuel was basic ULSD fuel intended for use in diesel engines. However, this sample was acquired PRIOR to any attempt to additize the fuel for the purpose of replacing lost lubricity. In other words, it was a “worst case scenario, very dry diesel fuel” that would likely cause damage to any fuel delivery system. This fuel was tested using the HFRR at the Southwest Research Laboratory. This fuel was determined to have a very high HFRR score of 636 microns, typical of an untreated ULSD fuel. It was determined that this batch of fuel would be utilized as the baseline fuel for testing all of the additives. The baseline fuel HFRR score of 636 would be used as the control sample. All additives tested would be evaluated on their ability to replace lost lubricity to the fuel by comparing their scores to the control sample. Any score under 636 shows improvement to the fuels ability to lubricate the fuel delivery system of a diesel engine.
BLIND STUDY:
In order to ensure a completely unbiased approach to the study, the following steps were taken:
Each additive tested was obtained independently via internet or over the counter purchases. The only exceptions were Opti-Lube XPD and the bio-diesel sample. The reason for this is because Opti-Lube XPD additive was considered “experimental” at the time of test enrollment and was not yet on the market. It was sent directly from Opti-Lube company. The bio-diesel sample was sponsored by Renewable Energy Group. One of their suppliers, E.H. Wolf and Sons in Slinger, Wisconsin supplied us with a sample of 100% soybean based bio-diesel. This sample was used to blend with the baseline fuel to create a 2% bio-diesel for testing.
Each additive was bottled separately in identical glass containers. The bottles were labeled only with a number. This number corresponded to the additive contained in the bottle. The order of numbering was done randomly by drawing names out of a hat. Only Spicer Research held the key to the additives in each bottle.
The additive samples were then sent in a box to An independent research firm. The only information given them was the ratio of fuel to be added to each additive sample. For example, bottle “A” needs to be mixed at a ratio of “480-1”. The ratio used for each additive was the “prescribed dosage” found on the bottle label for that product. Used motor oil and 2-cycle oil were tested at a rationally chosen ratio of 200:1.
The Research Laboratory mixed the proper ratio of each “bottled fluid” into a separate container containing the baseline fuel. The data, therefore, is meaningful because every additive is tested in the same way using the same fuel. A side-by-side comparison of the effectiveness of each additive is now obtainable.
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel.
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
1
ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
__________________
"03 2500 HD, Kennedy Mega Filter, STOCK PAPER AIR FILTER, Oilguard Bypass, Primrose, Baldwin Oil Filter, ARE Camper Shell, Line X Liner, Westin Nerf Bars.
Offline
Sponsored Links Remove Advertisements
Diesel Place Advertisement
SPICER
View Public Profile
Find More Posts by SPICER
Old 08-26-2007, 03:08 AM #2
SPICER
Diesel Fanatic
Would one of you kind moderators change the thread title to "LUBRICITY ADDITIVE STUDY RESULTS" for me please so I don't look like a dum dum who can't spell? Thank You! SPICER
__________________
Offline
SPICER
View Public Profile
Old 08-26-2007, 03:18 AM #3
Duratys
Diesel Master
Duratys's Avatar
View Photos By: Duratys
Send a message via MSN to Duratys Send a message via Yahoo to Duratys
Interesting results......Good work once again.
Ive never heard of the Opti-Lube XPD, is it available to the buying public yet?
__________________
04 SIERRA CC SB 4x4
Offline
Duratys
View Public Profile
Find More Posts by Duratys
Old 08-26-2007, 03:18 AM #4
Hammer 4
Diesel Master
Hammer 4's Avatar
View Photos By: Hammer 4
SoCal Diesel Trucks Member
Great work Spicer...apllause...
__________________
03 LB7..XCab..LB..LS..Summit White...Pro Comp ES 9000's..315 BFG at's on H2 Rimz..PPE Boost Valve..ISSPRO Gauges...SD Intake...Custom 4" Catback..Kennedy Airbox Mod...Custom 4" CAI
Offline
Hammer 4
View Public Profile
Find More Posts by Hammer 4
Old 08-26-2007, 03:24 AM #5
SPICER
Diesel Fanatic
I think it is available now. I just called for pricing so it could be added to the info. Look up Opti-Lube on an internet search for contact info. SPICER
__________________
Offline
SPICER
View Public Profile
Old 08-26-2007, 03:49 AM #6
SteveNorCal
Diesel Specialist
SteveNorCal's Avatar
Excellent work as usual, Spicer!
__________________
2004.5 LLY Silverado LT D/A 4x4 CC/SB in Summit White
Edge CTS w/Back-up Cam, Bilsteins, SS Bleed Screw, Fumoto Valve, Leer Cap, SS Cloud Riders, Toyo 265 AT's,
MBRP 4" System, OEM Bowtie Mud Guards, High Idle Mod by MaxPower, Cabin Air Filter Mod by TheBac
My other diesel is a John Deere 4400 12spd 4x4
05' Cougar 243RKS TT with Prodigy
Offline
SteveNorCal
View Public Profile
Find More Posts by SteveNorCal
Old 08-26-2007, 04:01 AM #7
coyotekid
Diesel Fanatic
coyotekid's Avatar
Well it comforts me to know I've been making the situation worse with FPPF for the last few months!
Thanks very much for all the hard work!
Was lubricity the only parameter measured? I'd be interested in anti-gel ability also...
__________________
2004.5 LLY/A Ex. Cab Short Box 4X4 LS Dark Gray Metallic
Duraflap Mudflaps, Marathon Seat Covers, Tekonsha Prodigy, Turbo Timer, 3M Clear Film on Rockers, Line-X, Catch-All Extreme Floor Mats, 15% Tint, High Idle Mod, Racor Pre OEM Fuel Filter, Cloud-Rider Winter Front, Predator, Suncoast LVIII and TTS Triple-Lock by "Pimp Daddy" Mike L., PML Deep Pan, SD Manifold, Trippin Gauge Mount, DiPricol Pre-Turbo Pyro and Boost, Axxess Ipod Interface, Finger Stick and EGR Plate, Boost Stick, Revo 265's
Founding Member and CEO of the "I'm an Insecure Adult and Need to Belong in a Club" Club
Offline
coyotekid
View Public Profile
Find More Posts by coyotekid
Old 08-26-2007, 04:13 AM #8
Arcing
Diesel Technician
Arcing's Avatar
View Photos By: Arcing
iTrader Score: 1 reviews
Idaho Turbo Diesels Member
Thanks Spicer
Thanks for all the work you've done here as well as past successes.
__________________
2004 GMC SLE EC SB LB7 D/A, Sand Beige Metallic, Outlook/Triple Dog, TTS Lift Pump/Xtra Filter, Westin Nerf bars, Bilsteins, Weathergaurd box, Silverline SS304 4 inch exhaust, TurboLiner, Transynd/deep pan. Fumoto valve, Diode Headlamp Mod, JD/Toshiba HIR, Michelin LTX-MS 265/75/16 on PYO. Firestone Ride Rite 2250s, Prodigy Brake Control, Garmin Nuvi 1350... New Horizons 34RLSSS fifth wheel @16k and '06 Nash 22H @7k. single and retired--
Currently: Yuma, Az.
POWER USED:
Original Power PUP-3/04-5/05
Edge Juice/Attitude- JUNKED-5/07
DiabloSport Predator U7180 5&6/07-Data only now
TripleDog/Outlook 6/07-present
Member of the White Smoke and Starts/Dies clubs. .................................... chickenfriedRV.com
Offline
Arcing
View Public Profile
Visit Arcing's homepage!
Find More Posts by Arcing
Old 08-26-2007, 05:14 AM #9
WanaDmxsub
Diesel Master
WanaDmxsub's Avatar
View Photos By: WanaDmxsub
As always, great job and THANK YOU!
__________________
'04 C2500HD D/A LS EC SB, Chrome Nerf bars, Prodigy, Weatherflector, Breezer, A.R.E. Z w/accordion boot, Bedrug, H2's, Bilsteins, Predator, VR Straps, Bowtie Flag, Mag-Hytec's, SPA Boost/EGT, Katless 4", BigMouth Grille, SD Manifold, SCIII .50 Hot Rod Allison/TTS triple, Airlift Superduty bags, Banks Bighead, Fugly '06 Mirrors, Van Aaken 230, Garvin Wilderness Rack, EFILive, Cognito Idler/pitman braces, SD intake
1) 04039B Special Coverage Adjustment (Injectors) '01-'04 LB7's
2) TSB #04-06-04-007G (Injectors) '01-'04 LB7's
3) 07057 – Special Coverage Adjustment Engine Glow Plug '02-'04 LB7's w/YF5/NE1
Offline
WanaDmxsub
View Public Profile
Find More Posts by WanaDmxsub
Old 08-26-2007, 05:43 AM #10
Mr BaadBoy
Diesel Specialist
Mr BaadBoy's Avatar
View Photos By: Mr BaadBoy
Results
Quiet a undertaking Spicer thanks from myself and my....... Girl 2003 Gmc lb7
__________________
2003 HD GMC CCSB Loaded/06 Tow Mirrors
White with Matching Jason Camper Top
Back Country/BLK Stainless Nerf Bars
244K...LB7/ Michelin AT2 265-75-16-E
Diablo Sport Predator 65 tow,120 dailyhttp://www.alligatorperformance.com/
High Idol Mod/ Duel Headlight Mod
Airlift SuperDuty/ Nuvi-350-
Swiss Cheese Air Box & Custom Lower Ram Air
Auto Meter/Boost & Pyro/ Cobolt Blue
Complete Blue Led Interior Lighting(except Damn Radio) PPE 160 Lift Pump/Pick-up
Insulated & Sound Proofed+ Rear Heated Seats
Cognito Steering Braces/Yellow Bilstiens http://dmaxstore.com/
Amsoil Duel Remote By-Pass +3 gal of marine 15/40 + Nictane Fuel Filter/ NEW Turbo-Horn Mod/ Me
4" Mbrp Exhaust+Rezonator Thx http://performancetruckproducts.com/
Offline
Mr BaadBoy
View Public Profile
Find More Posts by Mr BaadBoy
Sponsored Links
Follow AutoGuide.Com on Facebook! Click here
Closed Thread
« Previous Thread | Next Thread »
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
code is On
HTML code is Off
Forum Rules
Forum Jump
User Control PanelPrivate MessagesSubscriptionsWho's OnlineSearch ForumsForums Home Site Information Vendor Info & Specials Who sells [fill in the blank]? Introductions & New Trucks GM Diesel Engines Duramax Fifth Generation: 2011+ (LML) Duramax Fourth Generation: 2007.5-2010 (LMM) Duramax Third Generation: 2006-2007.5 (LBZ & LLY) Duramax Second Generation: 2004.5-2005 (LLY) Duramax First Generation: 2001-2004 (LB7) 4.5L Duramax (Upcoming) 6.5L Diesel Engine 4L80/85E Transmissions 6.2L Diesel Engine All Other GM Diesels Frankenstein GM Trucks Drivetrain Suspension & Steering Wheels & Tires Interior Exterior Electrical Maintenance & Fluids Bio-Diesel/Alternative Fuels and Supplements 3500 Dually Trucks Medium Duty Trucks Vans Buying or Selling a Truck GM Transmissions Allison OEM Allison Aftermarket ZF-6 OEM ZF-6 Aftermarket 4L80/85E Transmissions Power & Performance Fifth Generation Duramax Electronics Fourth Generation Duramax Electronics Third Generation Duramax Electronics Second Generation Duramax Electronics First Generation Duramax Electronics Custom Tuning Software EFILive Tuning Software HP Tuners Tuning Software Fuel System, Air, Exhaust, & Emissions Upgrades Propane, Nitrous, & Water Meth Other Performance Discussion Competition Competition Results Drag Racing Sled Pulling Bench Racing Off The Beaten Path Articles & Useful Information Do It Yourself, Useful Articles, & Product Reviews Official GM Information New Vehicle Information VIN Check Requests Warranty Issues & Recalls Other Vehicles GM Gassers Tractors Any Other Vehicles Other Topics SEMA 2009 SEMA 2010 Truck Uses Shop Talk Member Rigs Spotted Nicktane Filter Questions Towing Hauling Off Topic The Joke Place The Home & Property Place The Food Place The Guns & Ammo Place Market Place For Sale Parts - Chips & Tuners Parts - Engine & Drivetrain Parts - Electronics Parts - Exhaust & Intakes Parts - Miscellaneous Parts - Suspension Parts - Wheels & Tires Parts - Exterior Parts - Interior Parts - The Bone Yard Vehicles - Duramax Equipped Vehicles - All Other Miscellaneous 6.2/6.5 For Sale Medium Duty Truck Parts Closed "For Sale" Ads Wanted 6.2/6.5 Wanted Closed "Wanted" Ads Member Feedback Events, Rallies, & Regional Discussion Club Forums Club Details 702 Duramax Crew ALCAN Diesel Place Chapter Alberta Coal Rollers Armed Forces Club Badger State Diesel Club Buckeye Oil Burners CNY Diesel Club CT Smoke DelMarVa Diesel Club Diesel Day Dreams DINSTAAR Diesel DP Commandos Europe Georgia Diesel Owners Club Heartland Diesels Diesel Place Chapter (Oklahoma) Idaho Turbo Diesels Illinois Diesel Power (IDP) INDP Kansas Chapter DP Club KCDIESEL KY Diesel Place Club Lone Star Diesels Louisiana Diesel Truck Association Michigan Oil Burners Midwest Smokers Minnesota/Western Wisconsin DP Club Montana DP Member Club NC Dmax's Nor-Cal Diesel Place Club Northeastern Ohio Diesel Crew Northern Nevada Coal Rollers Ocean State Diesel Club Old School Oil Burners (Old SOBs) Ontario Diesel Place Chapter Pacific Iron Mountain Truck Club Quebec/Labrador Diesel Place Chapter SoCal Diesel Trucks TN Diesel Place Club National Northwest Southwest North Central South Central Great Lakes Northeast Mid-Atlantic Southeast Canada Vendors Comments Sponsor Zone Adrenaline Motorsports Inc. Agri-Cover All Season Sales & Service Alligator Diesel Performance ATS Diesel Performance Banks Power Systems BD Engine Brake BD Power Big Hog Customs BND Automotive Bully Dog Technologies BuyMonsterDiesel.com CARiD.com Cool Tech LLC Danville Performance DC Power Engineering Diesel Performance Products Discount Tire Direct DMAXSTORE DPF Performance Duramax Tuner Duramileage Edge Products EFILive Fleece Performance Engineering Flowmaster Mufflers Hog Performance HP Tuners Huckstorf Diesel Hypertech Inc. Inglewood Transmissions ISSPRO K&N Filters Kennedy Sales and Service Labonte MotorSports, LLC LubricationSpecialist.com Magnaflow MadJack Racing Maximized Performance Inc. MBRP Inc. MemberCalendars.com Merchant Automotive Meyer Performance MGT Motorsports Nicktane Nor Cal Truck Pacific Performance Engineering (P.P.E.) Performance Accessories Performance Truck Products Randy's Ring & Pinion Retro-Solutions Rock Auto Rolling Big Power S&B Filters St. Joseph Diesel Inc. Shifted Perceptions Shocker Motorsports Shock Warehouse Showtime Fabrication SoCal Diesel Southwest Wheel Co. Superchips The Choppin' Block TheSuperiorSynthetic.com Thoroughbred Diesel Top Gun Customz trail master Truck Mojo US Speedo Viair Corp Xtreme Diesel Performance YourGMParts.com Body Kits Rims Exhaust Systems Garage Storage and Cabinets
Ads by Google
Diesel Turbos
Cummins Diesel
GMC Duramax Diesel
Diesel Engine
Contact Us - Diesel Place - Archive - Privacy Statement - Top
© AutoGuide
* AutoGuide.com
* Truck
* European
* Import
* Domestic
* Manufacturer
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
Visit AutoGuide.com today.
For advertising information, on the AutoGuide.com network please request a media kit or email us: [email][email protected][/email]
DOMESTIC
CherokeeSRT8.com
CumminsForum.com
ColoradoFans.com
Dakota-Durango.com
DieselPlace.com
Dodge-Nitro.com
DuramaxForum.com
FullsizeBronco.com
H2Fanatic.com
JeepCommander.com
Powerstroke.org
S10forum.com
SSRFanatic.com
TheDieselStop.com
Trailvoy.com
IMPORT
ClubArmada.com
ClubFrontier.org
ClubTitan.org
ClubXterra.org
CrosstourOwnersClub.com
CRVownersClub.com
CustomTacos.com
FJCruiserForums.com
MDXers.org
NissanMurano.org
Piloteers.org
Rav4World.com
RidgelineOwnersClub.com
TitanTalk.com
TundraSolutions.com
TundraTalk.net
ZDXforum.com
EUROPEAN
LandRoversOnly.com
1SeriesOnline.com
AudiA1forum.com
BoxsterForums.com
Fiat500owners.com
NewBeetle.org
R8Talk.com
PassatWorld.com
MANUFACTURER
Audi-Forums.com
BenzForum.com
BenzWorld.org
BimmerWerkz.com
Ferrari-Talk.com
Lamborghini-Talk.com
LotusTalk.com
Mini2.com
SaabScene.com
SmartCarOfAmerica.com
Volvo-Forums.com
VWforum.com
TRUCK
LandRoversOnly.com
240sxForums.com
350z-tech.com
3si.org
6mt.net
7thGenHonda.com
8thCivic.com
Acura-Legend.com
B15Sentra.net
Club3g.com
CT200Hforum.com
Crz-Craze.com
CubeForums.com
DriveAccord.net
D-Series.org
DSMTalk.com
ElementOwnersClub.com
EVOTuners.net
EvoXforums.com
FitOwnersClub.com
ForteForums.com
FR-Sforum.com
GenCoupe.com
GenesisForums.com
GenesisForums.org
HybridForums.org
InsightCentral.net
IQcolony.com
IQ-Forums.com
JukeForums.com
KiaSoulForums.com
LexusFforum.com
Mazda3revolution.com
Mazda6Club.com
MX6.com
My.IS
NewScionXB.com
NissanCubeLife.com
OdysseyOwnersClub.com
OdyClub.com
OptimaForums.com
PreludeOnline.com
PreludePower.com
SR20Forum.com
SubaruForester.org
SubaruOutback.org
ToyotaCelicas.com
TSXclub.com
Veloster.org
WRXTuners.com
YourScionTC.com
MANUFACTURER
AcuraWorld.com
Hyundai-Forums.com
HyundaiPerformance.com
Kia-Forums.com
MazdaWorld.org
Mitsubishi-Forums.com
NissanClub.com
NissanForums.com
ScionForum.com
SuperHonda.com
Suzuki-Forums.com
ToyotaNation.com
TRUCK
ClubArmada.com
ClubFrontier.org
ClubTitan.org
ClubXterra.org
CRVownersClub.com
CustomTacos.com
FJCruiserForums.com
MDXers.org
NissanMurano.org
Piloteers.org
Rav4World.com
TitanTalk.com
TundraSolutions.com
TundraTalk.net
ZDXforum.com
200Forums.com
300cForums.com
355Nation.net
460Ford.com
CaliberForums.com
Camaros.net
ChevyMalibuForum.com
ChallengerTalk.com
ChargerForums.com
Chevelles.com
CobaltSS.com
Corvette-Forum.com
CruzeTalk.com
DodgeIntrepid.net
DigitalCorvettes.com
FordGT500.com
G6OwnersClub.com
G8board.com
G8Forum.com
GTOForum.com
Hornet-Forum.com
Impalas.net
JeepPatriot.com
LS1GTO.com
LS1LT1.com
ModdedMustangs.com
NewAgeGTO.com
NewCougar.org
Novas.net
RedlineForums.com
RegalForums.com
SkyRoadster.com
SolsticeForum.com
SolsticeForums.com
SRT10Forum.com
StevesNovaSite.com
TaurusClub.com
TurboDodge.com
Vintage-Mustang.com
ViperAlley.com
VoltForums.com
Vseries.net
XLRForum.com
Z06Vette.com
TRUCK
CherokeeSRT8.com
CumminsForum.com
ColoradoFans.com
Dakota-Durango.com
DieselPlace.com
Dodge-Nitro.com
DuramaxForum.com
FullsizeBronco.com
H2Fanatic.com
JeepCommander.com
Powerstroke.org
S10forum.com
SSRFanatic.com
TheDieselStop.com
Trailvoy.com
MANUFACTURER
ChevyTeam.com
FordForums.com
DodgeTalk.com
FordInsideNews.com
GMinsidenews.com
SRTforums.com
MUSCLE & CLASSICS
460Ford.com
Camaros.net
Chevelles.com
ChevyTeam.com
Corral.net
DFWStangs.net
ElCaminoCentral.com
FordMuscleForums.com
GTOforum.com
Impalas.net
ImpalaSSForum.com
Novas.net
StevesNovaSite.com
Vintage-Mustang.com
AcuraWorld.com
Audi-Forums.com
BenzForum.com
BenzWorld.org
BimmerWerkz.com
DodgeTalk.com
Ferrari-Talk.com
FordForums.com FordInsideNews.com
GMinsidenews.com
Hyundai-Forums.com
Kia-Forums.com
LandRoversOnly.com
LotusTalk.com
MazdaWorld.org
Mini2.com
Volvo-Forums.com
Nissan-Sites.com
NissanClub.com
NissanForums.com
ScionForum.com
SaabScene.com
SRTforums.com
SuperHonda.com
Suzuki-Forums.com
ToyotaNation.com
VWforum.com
Terms of Use
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Ads by Google
Diesel Turbos
Cummins Diesel
GMC Duramax Diesel
Diesel Engine
User Name SAVE
Password
Register Showroom
Showroom
Showrooms
Browse by Username
Browse Most Popular
Advanced Search
Help
Live Chat
Enter Live Chat
Who's Chatting?
Go to Page...
Closed Thread
Thread Tools
SPICER
Diesel Fanatic
PURPOSE:
HISTORY:
CONTENT:
METHOD:
BLIND STUDY:
THE RESULTS:
Price: market value
2)Opti-Lube XPD
256:1 ratio
13 oz/tank
$4.35/tank
Gas and Diesel
640:1 ratio
5.2 oz/tank
$2.60/tank
Multi-purpose
demulsifier
3000:1 ratio
1.11 oz/tank
$0.68/tank
cetane improver
512:1 ratio
6.5 oz/tank
$3.65/tank
1000:1 ratio
3.32 oz/tank
$1.87/tank
200:1 ratio
16.64 oz/tank
$1.09/tank
Lubricity Only
1000:1 ratio
3.32 oz/tank
$1.00/tank
Multi-purpose
640:1 ratio
5.2 oz/tank
$2.16/tank
Multi-purpose
400:1 ratio
8.32 oz/tank
$1.58/tank
Multi-purpose
Alcohol free
1000:1 ratio
3.32 oz/tank
$1.36/tank
480:1 ratio
6.9 oz/tank
$4.35/tank
200:1 ratio
16.64 oz/tank
price: market value
Gas or diesel
427:1 ratio
7.8 oz/tank
$2.65/tank
1000:1 ratio
3.32 oz/tank
$2.67/tank
1000:1 ratio
3.32 oz/tank
$1.12/tank
320:1 ratio
10.4 oz/tank
$3.22/tank
1
Multi-purpose
1000:1 ratio
3.32 oz/tank
$2.38/tank
Multi-purpose
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
CREDITS:
__________________
Offline
SPICER
View Public Profile
SPICER
Diesel Fanatic
__________________
Offline
SPICER
View Public Profile
Duratys
Diesel Master
Duratys's Avatar
__________________
04 SIERRA CC SB 4x4
Offline
Duratys
View Public Profile
Hammer 4
Diesel Master
Hammer 4's Avatar
__________________
Offline
Hammer 4
View Public Profile
SPICER
Diesel Fanatic
__________________
Offline
SPICER
View Public Profile
SteveNorCal
Diesel Specialist
__________________
Offline
SteveNorCal
View Public Profile
coyotekid
Diesel Fanatic
coyotekid's Avatar
__________________
Offline
coyotekid
View Public Profile
Arcing
Diesel Technician
Arcing's Avatar
Thanks Spicer
__________________
POWER USED:
Offline
Arcing
View Public Profile
WanaDmxsub
Diesel Master
WanaDmxsub's Avatar
__________________
Offline
WanaDmxsub
View Public Profile
Mr BaadBoy
Diesel Specialist
Mr BaadBoy's Avatar
Results
__________________
Offline
Mr BaadBoy
View Public Profile
Sponsored Links
Closed Thread
Thread Tools
Posting Rules
BB code is On
Smilies are On
code is On
HTML code is Off
Forum Rules
Forum Jump
Ads by Google
Diesel Turbos
Cummins Diesel
GMC Duramax Diesel
Diesel Engine
© AutoGuide
* AutoGuide.com
* Truck
* European
* Import
* Domestic
* Manufacturer
DOMESTIC
CherokeeSRT8.com
CumminsForum.com
ColoradoFans.com
Dakota-Durango.com
DieselPlace.com
Dodge-Nitro.com
DuramaxForum.com
FullsizeBronco.com
H2Fanatic.com
JeepCommander.com
Powerstroke.org
S10forum.com
SSRFanatic.com
TheDieselStop.com
Trailvoy.com
IMPORT
ClubArmada.com
ClubFrontier.org
ClubTitan.org
ClubXterra.org
CRVownersClub.com
CustomTacos.com
FJCruiserForums.com
MDXers.org
NissanMurano.org
Piloteers.org
Rav4World.com
TitanTalk.com
TundraSolutions.com
TundraTalk.net
ZDXforum.com
EUROPEAN
LandRoversOnly.com
1SeriesOnline.com
AudiA1forum.com
BoxsterForums.com
Fiat500owners.com
NewBeetle.org
R8Talk.com
PassatWorld.com
MANUFACTURER
Audi-Forums.com
BenzForum.com
BenzWorld.org
BimmerWerkz.com
Ferrari-Talk.com
LotusTalk.com
Mini2.com
SaabScene.com
Volvo-Forums.com
VWforum.com
TRUCK
LandRoversOnly.com
240sxForums.com
350z-tech.com
3si.org
6mt.net
7thGenHonda.com
8thCivic.com
Acura-Legend.com
B15Sentra.net
Club3g.com
CT200Hforum.com
Crz-Craze.com
CubeForums.com
DriveAccord.net
D-Series.org
DSMTalk.com
EVOTuners.net
EvoXforums.com
FitOwnersClub.com
ForteForums.com
FR-Sforum.com
GenCoupe.com
GenesisForums.com
GenesisForums.org
HybridForums.org
InsightCentral.net
IQcolony.com
IQ-Forums.com
JukeForums.com
KiaSoulForums.com
LexusFforum.com
Mazda6Club.com
MX6.com
My.IS
NewScionXB.com
NissanCubeLife.com
OdyClub.com
OptimaForums.com
PreludeOnline.com
PreludePower.com
SR20Forum.com
SubaruForester.org
SubaruOutback.org
ToyotaCelicas.com
TSXclub.com
Veloster.org
WRXTuners.com
YourScionTC.com
MANUFACTURER
AcuraWorld.com
Hyundai-Forums.com
Kia-Forums.com
MazdaWorld.org
NissanClub.com
NissanForums.com
ScionForum.com
SuperHonda.com
Suzuki-Forums.com
ToyotaNation.com
TRUCK
ClubArmada.com
ClubFrontier.org
ClubTitan.org
ClubXterra.org
CRVownersClub.com
CustomTacos.com
FJCruiserForums.com
MDXers.org
NissanMurano.org
Piloteers.org
Rav4World.com
TitanTalk.com
TundraSolutions.com
TundraTalk.net
ZDXforum.com
200Forums.com
300cForums.com
355Nation.net
460Ford.com
CaliberForums.com
Camaros.net
ChallengerTalk.com
ChargerForums.com
Chevelles.com
CobaltSS.com
Corvette-Forum.com
CruzeTalk.com
DodgeIntrepid.net
FordGT500.com
G6OwnersClub.com
G8board.com
G8Forum.com
GTOForum.com
Hornet-Forum.com
Impalas.net
JeepPatriot.com
LS1GTO.com
LS1LT1.com
ModdedMustangs.com
NewAgeGTO.com
NewCougar.org
Novas.net
RedlineForums.com
RegalForums.com
SkyRoadster.com
SolsticeForum.com
SolsticeForums.com
SRT10Forum.com
StevesNovaSite.com
TaurusClub.com
TurboDodge.com
Vintage-Mustang.com
ViperAlley.com
VoltForums.com
Vseries.net
XLRForum.com
Z06Vette.com
TRUCK
CherokeeSRT8.com
CumminsForum.com
ColoradoFans.com
Dakota-Durango.com
DieselPlace.com
Dodge-Nitro.com
DuramaxForum.com
FullsizeBronco.com
H2Fanatic.com
JeepCommander.com
Powerstroke.org
S10forum.com
SSRFanatic.com
TheDieselStop.com
Trailvoy.com
MANUFACTURER
ChevyTeam.com
FordForums.com
DodgeTalk.com
FordInsideNews.com
GMinsidenews.com
SRTforums.com
MUSCLE & CLASSICS
460Ford.com
Camaros.net
Chevelles.com
ChevyTeam.com
Corral.net
DFWStangs.net
ElCaminoCentral.com
GTOforum.com
Impalas.net
ImpalaSSForum.com
Novas.net
StevesNovaSite.com
Vintage-Mustang.com
AcuraWorld.com
Audi-Forums.com
BenzForum.com
BenzWorld.org
BimmerWerkz.com
DodgeTalk.com
Ferrari-Talk.com
GMinsidenews.com
Hyundai-Forums.com
Kia-Forums.com
LandRoversOnly.com
LotusTalk.com
MazdaWorld.org
Mini2.com
Volvo-Forums.com
Nissan-Sites.com
NissanClub.com
NissanForums.com
ScionForum.com
SaabScene.com
SRTforums.com
SuperHonda.com
Suzuki-Forums.com
ToyotaNation.com
VWforum.com
Terms of Use
