Chainsaw Rebuilder?
  • Thread starter Thread starter Bodean
  • Replies Replies 101
  • Views Views 16K
But the little inanimate things are gifted to do that, as much as the animate things (may I call them people?).:D
The crankshaft of my 064 broke at the clutch 2,5 years ago. Never took the time to fix it, until the bearing failed on my ms440 (well planed maintenance !). I already had the new crankshaft, so I put it in place. After struggling a bit with the bearings and seals, closing back the half cases ended well. But when I tightened the cylinder's screws, one of them stripped the case's thread.:X
I hope I'll fix that before two and a half years;)
I some times use the bolts that tread hole them self as a quick fix. If you get right with length and metal (so it takes the temps) it will sit just as well, if not better.
