Marc-Antoine
Frequently, after one year of daily use of the ms200T, this saw begins acting. No more straight acceleration, great loss of power, instable idle. We can get only some sort of useless WWAAAAABEEEUU.
The saw run very lean, no more enough gas to run properly.
It is too soon in the saw's life for the well known troubles with membranes and needle, usual air leaks, and the other gas starvations.
I already knew the cracking aluminum body on the small Zama (thanks Al).
But for the "1 year old" issue on the 200T, so common, it couldn't be those possibilities.
I understood that it could be some wear in the carb, but which one, how, what's going?
I didn't saw anything so quickly used in a so simple mechanic like a carb, able to give those symptoms.
So, I look after some informations on this f*** carb.
I found the answer on AS, where a guy put together a bunch of posts on this subject (explanations and solutions).
http://www.arboristsite.com/chainsaw/145024.htm
First consideration, in order to pass the new environmental laws, Stihl restrains his engines by the exhaust and by the carb, adjusted the most lean as possible, a story you all know very well.
Problem, the saw seems to become sleepy when man pulls the trigger, since it lacks on energy.
To wake it up a little, they add in the carb an accelerator pump (at a small scale) like the big carbs in the cars.
At each actuation of the trigger, the throttle's axle pushes a small piston, which send an additional drip of gas to the main jet. And go on, vroaaaar !
But the small brass piston (5 mm diam.) and his tiny bitty O-ring wear fast. The tightness is lost and some air comes trough the pump in the gas, before reaching the jets. Obviously, it doesn't run very well now, and instead of "vroaaar", it's more like waabeeeuuu !
Different solutions are possible, more or less costly, easy or long lasting (like putting a new carb or repairing the accelerator pump).
The one I choose costs a few bucks, is easy if you are a little "mechanic's lover" and lasts the saw's life. The onliest downside is a small loss of acceleration, (theoretically) but the max speed and torque don't change.
So, here's the way to repair and enhance the reliability of the ms200T's carb Zama C1Q-S61 (or S126 for mine).
The main goal is to neutralize the accelerator pump whose lifetime is too much short.
Given that this pump isn't really indispensable for the system, we can solve the problem definitely, and at a very low cost.
First step, we take the carb out of the engine. Even if the main operation could be done with the carb still in place, it's easier to work on it in hand.
The pics have some strange colors because my camera pull to the yellow with the kitchen light, and I have a hard time to give them again a "natural" aspect.
Here's the carb, seen from the engine side, with the throttle's valve. The brass cup (green arrow) closes the machining bore for the pump. This one is actually located deeper in the carb's body, between the throttle's axle and he choke's axle.
The carburettor, seen from the "air filter" side, with the choke's valve. The green arrow shows the small aluminum plate which closes an other machining bore. This one is there to drill the way between the pump and the usual internal canals (supply in gas for the jets).
We'll operate here.
With an sharp blade, pry out the small oblong alu plate. Take care of your fingers, the plate is both crimped and glued.
We find below two canal's entrances.
The left canal, very obliquely, reaches to the pump's bottom, located just behind the choke's axle.
The right canal goes down to the main jet (the bump on the top of the ventury tunnel). The needles help to visualize their directions.
The operation consists in blocking the way between the both canals. That's enough to completely isolate the pump and, more important, close the access to the gas supply and the jets.
One drip of grease remover and blow to dry the place.
Then, put a small quantity of epoxy glue to fill the both canal's entrances and the oblong machining cup. The good point with the epoxy-alu blend (like this Loctite or your JCB weld) is that it has enough viscosity to avoid deep penetration where it shouldn't go. A metal paper-clip has the right diameter to push a little bit of epoxy in the small holes. You need only one or an half rice seed of glue, but you will lost 10 times more just to get a good blend.
Be sure that the epoxy is well flattened and doesn't rise over the carb's back area. Otherwise, there will be a gap between the carb and the inox plate behind the air filter box.
Now, just wait one full day before the reassembly: the epoxy glue must be well settled to avoid trouble with the gas.
Then, adjust the settings for the idle (screw L and LA), eventually the H screw (if modified during the troubles), and the chainsaw is ready to go.
That's all.
The following is an option for the curious (like me).
Before the reassembly, I wanted to see at what looks like this pump in real. The drawing on the parts list is very small and a little disappointing.
In order to see the pump (and get it), you have to remove the throttle's axle (the one on the engine side) :
- loosen the springs of the choke and the throttle
- unscrew the center screw on the throttle valve and take out this one
- take out the circlip on the end of the throttle's axle
- take off the carb side that hold the throttle stop (screw LA)
- rotate the throttle's axle 180° to push the small piston pump back in his room (in the normal position, the piston bears on a notch in the axle and prevent this one to get out, so do not force it as is).
- pull the axle out of the body, and here comes the piston, visible in the axle housing:
- with a thin rod and a little tap, push out the closing brass cup by the inside ( pass by the axle housing, very obliquely). Careful to not damage the aluminum body.
- work gently the piston and it goes out with its spring (small but strong for its size).
Sadly, my camera isn't good enough to show you the wear on the piston and on its O-ring.
At the bottom of the pump housing, there's a very small metal mesh filter, then the canal's entrance we closed at the other end.
Here is the arrangement of the different parts, like an exploded view :
Put again in place the axle, the circlip, the valve (position it very precisely) and its screw, the carb side, the brass cup (to be sure no debris could come in and jam the axle), then tighten the throttle's and choke's springs.
I trashed the piston and it's spring, so there's no more stress and wear on the axle from them.
End of the option.
Now, the chainsaw is reassembled, tunned and tested.
YES, it works!
You can see the pics from the first one, but actually, I repaired 3 Ms200T by this mean.
I took out the 3 pumps to avoid permanent pressure and wear on the axles.
All 3 chainsaws work very well. They get again a good beat in the wood, without any hole, speed loss, irregular idle, or dying.
And honestly,I'm not able to see the small acceleration loss. (but perhaps am I a little biased )
That's all good !
I hope that will be even useful for you as it was for me.
(and I hope too there aren't too much strange sentences by my translation and that remains understandable).
We'll operate here.
That's all.
	End of the option.
YES, it works!
)That's all good !
