Any reviews on the Elvex specs from Treestuff?
What I look for in safety glasses is an absence of a lower frame.
My sweat pools in the bottom of full framed glasses. As I look down then up, the sweat swirls and stains the entire lens.
Do you think the vents would allow for sweat drainage?
What happens to me when it's summer, as I look down, the sweat from my helmet streams down and some ends in my glasses.
What I just noticed about these are that they're sealed, so that may keep that from happening. But would be hot from the foam against the face, even with the vented bottom. I wonder.
As for the vented bottom -and sweat created within the lenses, as it goes to drain thru the vents— and from what I've found in several Oakley glasses for cycling as well is; sometimes the sweat isn't heavy enough to pass thru the holes— if that makes sense. It'll just swish side to side until it's deep enough to drain.
But none of this is a problem if the weather is cooler, so I'm sure these would be stellar.
