Ed L
The EAB Ash in my woods are starting to fall on a regular basis now, they will uproot or snap off near the ground. Doesn't take a lot of bad weather to send them over.
One of the latest stumps. Tree was only 10" dbh, but 60' long.
Which left me with this. Over 7' in the air.
Fun eh? As you can see, theres a little tension...........
After an hours worth of clean up in the area as there are other Ash to fell, a little work with the pole pruner, its a little easier to access.
Still lots of tension, I cut from the north side, as the tree was heading south.
It swung around far enough to hit the nearest tree behind it.
All said & done, it had turned 90 degrees from where it started.
Everything went pretty smooth on this one, took my time and thought everything through. No reason to rush and get hurt.
Ed
Ed
