Spellfeller
Clueless but careful
Hi, all:
Work has a Vermeer BC935 that I can borrow. Not sure whether it has the gas (35hp) or one of the two diesel engines (42hp & 50hp)...I need to check that, for sure. If for no other reason than to fuel it properly!
I know the infeed is 9" x 9", but I doubt that means I can chuck an 8.75" oak limb in there just because it will fit, right? What diameter material is the upper limit of what the chipper can handle? Does it depend largely on which engine & its torque specs?
Also, I know that I should 1) wear PPE 2) not reach past the end of the table and 3) should feed branches butt first. Any other safety practices that would be good to follow?
