Mine is lame.....it has no tig welder or milling machine in it yet.
Mines always a disaster
I almost burned my shop down.
You know you can rail you own bars easy enough with a tablesaw fitted with a metal cut off wheel, so no need to go into town.I'm sure a cheap portable tablesaw would work, you just have to make an insert for the cut off wheel center which is probably larger than the saw arbor. Wear safety glasses.
