dastevoe
Wood Hacker
Grabbed my (2) 038's,1 mag & 1 super, to take to the woodlot to get some cutting time on them after rebuild/port job. Do you think I could get those suckers started ? Just about wore my arm out
So I pulled the filters dribbled in a bit-o-mix and after a couple attempts they start.Ran great in and out of the wood. Shut it off and set it down for 5-10 min., then back to the tug of war
Whats goin' on here ??
The mag. wasn't as ornery but when I got home (~1hr),I thought I'd give them another go,well.....no-go
Any ideas ?, didn't put carb kits in at rebuild though.Also saws have been sitting in heated shop for a couple of weeks.
Thanks
Steve
.So I pulled the filters dribbled in a bit-o-mix and after a couple attempts they start.Ran great in and out of the wood. Shut it off and set it down for 5-10 min., then back to the tug of war
Whats goin' on here ??The mag. wasn't as ornery but when I got home (~1hr),I thought I'd give them another go,well.....no-go
Thanks
Steve
Better not need the carb kit or I'll want a refund.
.Same procedure on the Mag. ,however every time I choke it the bottom of the filter flexes away from the carb (just slightly,but noticeable), NO STARTY. So I switch filters from Super to Mag, ensure it's fitting nicely ,3 pulls away she goes.
