Ya, Gary, if you start at 6, insert wedges past 9 and 3. Exit at 12, both hands on saw, not shockloading your arm with a saw swinging away, possibly with the engine running, chainbrake disengaged.
When you get to the far side, the piece will tilt back, over the wedges, resting at 6:00.
FWIW,
A third wedge can replace a hatchet/ ax as a pounder, if you need to make the wedges tight, maybe on heavy and squishy cottonwood, for example.
By the time the wedges fall out while pushing forward, the work-piece will be somewhat balanced near the lip or already over the lip. Then, it won't take much effort to tilt over.
Gord demonstrated the Magic-Cut way back, on TB. It basically a face-cut that undercuts the COG of the piece, with a full width dutchman, and a lower, horizontal release cut. No Hinge.
AKA Sniped, Snap-cut. The snipe will give you directional control on a vertical spar. The snipe will give you some directional control if you have lean to the work...if its leaning to 12:00, you can steer to 11:00 or 1:00, +/-.
No need to make a proper face-cut and fight a hinge IF the lean is working with you. Counter-productive, actually, IMO.
When I'm working a vertical spar down, I'll layout the logs side by side, so that I don't bounce one of the other, when I have a dropzone that will take the beating, one way or the other. My groundie(s) stay away from the area, doing work elsewhere. I stay focused. No pull ropes or coordination. Logs are laid out ezpz for the loader, or to roll with peaveys, or just leave in place.
I think people overthink the Magic-cut, honestly.
Remember Jerry's story about the Coos Bay cut, listening to the technique being relayed over many a beer, but sorta in disbelief...NO HINGE!! Simple cut, easy to execute by comparison, and functioning in a different way that a directional-felling cut. You don't use a hammer when you need a screw-driver.
Been burning the candle at both ends. Trying to chill out this weekend. I'll try to make a picture-heavy thread. I couldn't do this work if not for all the techniques that I've cherry-picked. Said it before, I come up with almost none of this. I just put other people's tricks in the bag, and try to use them precisely. Saves sooo much work.
Now, back to your regular programming.
