While the guy was here with the dozer last week pushing up my burn piles and such, I had him push off some hedges/brush/undergrowth that was taking over the lower part of my yard. I discovered a wonderful place to hang a new tree swing. A two-liner, that will allow some HIGH swinging. I have to climb the tree (red oak), and take off one dead limb and one other limb that will impede the swinging, as well as lighten the limb the swing will be attached to. My quandary now is attachment method. Years ago (like 22 years ago), I ran a piece of 3-strand 1/2” rope I’d brought home from Asplundh up onto a big limb on a red oak, and my girls enjoyed it for years. The limb did begin to grow over the running bowline after several years, and the end of the limb began to sir back, so I climbed it and cut the limb off. Paul sent me a piece of Wraptor rope (about 80’), and I attached it to a main fork in the top of the same big red oak, routing it out through a fork on a limb above where the old swing had been, giving them an even higher swing. That lasted about a year, and the jacket began to rub through from the friction in the lower fork, so I replaced it with a piece of 3/4” Multiline, which is still there, and still doing fine.
I have ordered a length of 1/2” Treemaster for the new swing, but can’t decide if I want to bore through the limb and use eye bolts, if I want to simply use running bowlines (and climb it a couple times a year to inspect/loosen them, or if I want to utilize tree straps. Any thoughts? Limb is about 35’+/- where I’ll be attaching the lines. I’ve always been hesitant to use hardware, but a quick web search shows lots of folks are using eye bolts nowadays. I could a guy on YouTube who has a business installing tree swings and he uses eye bolts as his method.
