Al Smith
Mac Daddy
Seals in general really .Husqvarna for one uses square shouldered bearing and seal surfaces on the crankshaft .In a situation like that it would very easy to missinstall a seal causing a failure as some have found out unfortunately .
A very simple method is to use the thin plastic from a tube they often use to package drill bits,cigars or any number of round items .You split the tube so it kind of acts as a shoe horn funneling the seal over the shoulder .Just oil it up,install the seal,pull out the plastic .
The pic is a little blurry but it's all I have at the moment .Plus the situation is staged for an example because on that practicular saw ,Huskey 281 the seal is installed in the oil pump housing .Not over the shaft as shown .
