346xp vs 357xp
Koala
Italia
There's a special offer at the local local Husqvarna dealer on 346, 357 and 372.It will last till january.
They're pushing a lot the new 562xp and 560xp, so they give a good price on the others.
I was thinking to get a 357xp, even if i consider the 346 a good saw.
Any suggestion about it?
Thanx.
All three are excellent saws but they are in different categories. Buy the size you need, they are excellent choices. Buy a 372 also if you can afford it.
357 is what I need more at the moment.
372 is my favourite saw ever, but MS 440 is still running so... next time.
  • #4
Don't know the prices there , 372 is 930 euro(200 less than before), more or less 1240 US dollars.
The 365xp x-torq 70.7cc strato is a 372xp x-torq 70.7cc strato. Only difference the 365xp has a restricter plate that is easily removed. Difference in prices $6something to $8something. I was quoted $550 for the 365xp the other day, not bad for a 71cc saw. Just so you know.
Thread on subject that dates back to May 2011 http://chainsawrepair.createaforum.com/husqvarna/husqvarna-365-xt/
Are you sure about that? It seems the 372 x-torq is a North America pet. I looked around for the X-torq versions here and they are not available, only the normal engine in 372.
I think chances are these saws in Italy is same.
Making shelf space and ending a era in selling last old out.
357, 372 is available here for order this year, and beginning of next...
The 357 seems like a real purposeful saw if felling in the 20" plus minus range. With the displacement you should be getting more power compared to the 346.
Im nuts over the 346 myself. I live for the 372 but if you need a small saw, the 346 will make you smile.
LOL not many dealers will tell you yes the 365xp is 70.7cc and that the restricter plate can be pulled easily. But in the thread I posted here a dealer is telling you so ;) , so yes I am sure.
Specifications for 365 XP
Engine specification Cylinder displacement 70.7 cc
Idling speed 2700 rpm
Cylinder bore 1.97 inch
Cylinder stroke 1.42 inch
Ignition system FHP
Spark plug Champion RCJ7Y, NGK BPMR7A
Electrode gap 0.02 "
Carburetor model name C3M-EL2B/-EL8A
Fuel tank volume 1.62 US pint
Oil tank volume 0.84 US pint
Oil pump capacity 0-0.021 ml/min
Air filter type Felt
http://www.husqvarna.com/us/homeowner/products/chainsaws/365-xp/#features
Ignition system FHP
I was more referring to X-Torq. As we don't have them here, I thought you could be interested in knowing this.
365 we have not had in product list for quite some time...
Sorry about the derail, and i always seem to throw in these older saws into the newer one's discussion....anyone with experience running a Husky 444? i see one up for auction here, and it's the first time I have seen mention of the model. it looks interesting.
Thanks.
I ran 44 and 444 a lot.
Not bad saws with exception of the crappy ignition system.
In Japan you find them labled as other things to. I have 644, 445SE for example...
The few mentions of the 444 that I have found on the internet, are much in keeping with what Steve says about his.
I have all three and they are all excellent saws. My 346 is set up with a 20" bar for reach and is used for limbin and climbing/bucket work. 357 with an 18" bar for firewood and general ground work. 372 with 28" full skip for the bigger wood.
  • #18
Thanks guys.
I'm thinking about the 357 with a 18"or 20" bar.
@flushcut
Is it just a matter of weight your choice of using the 346 in the tree instead of the 357?
The 346 is not losing in power a little bit with a 20" bar?
357 run great with 16" .325 and 18" if it is 3/8.
More than that they tend to get hot as it is more of limbing saw than felling saw.
If I were you I would try to get a non x-torq 372. Not much different in prices compared to difference in saw.
  • #20
Good point. Difference in price is only 80-90 €.
I'm just looking for a good saw to bring up in the tree , something in the middle between a 200T and a MS 440.
My back keeps gettin less and less happy with heavy saws.
Yes Magnus the 365xp and 372xp are both x-torq like I mentioned in 1st post. I thought it was odd they called the new 365XP. Which to me the closed port 365 special was in my mind anyways back then too. I would have only considered the open port 365 a non xp.
I have yet to come across a 365 that wasnt closed port even though I know the are out there.
Something else I noticed was the factory specs on the x-torq saws 365 372 jonsered sister saws 2166 2171 show a weight gain in PHO. 14.1lb to the old 13.6lb
Thanks guys.
@flushcut
For me it is the weight and that's way I prefer the 346 and she seems to do just fine with a 20" bar and is better on fuel than a 357. If you don't mind the weight a 357 with a 20 or 22" bar would be a great choice. I have a 24" for it but the balance is really funky and nose heavy. The 357 is my favorite saw all around for a smallish saw but not for climbing IMO.
The 444 was a great saw for limbing. I ran a couple of them in my pulp cutting days.
I remember nothing bad about them.
