Ax-Man
Don't make me chop you
Just thought I would pass this along.
Working on my old 028 Super that developed an air leak in the seal on the clutch side. The clutch has to come off to get at. The darn thing was being stubborn last night. Even with my son holding down the saw with his feet so I could work with both hands that darn clutch wouldn't move because my regular chrome deep well sockets just couldn't get a good bite because they just wouldn't fit up snug enough to the hub. they kept slipping off to the side becauase the clutch nut is very thin and not much for socket to grab onto. I ran into this same problem on another 28 but I finally got that one broke free, this one was not cooperating at all.. A three sided spanner wrench would be the ideal tool but I don't have one that would fit a 28 clutch.
Before I really screwed things up I decided to see if an impact socket would work any better.They do and give a much better fit on the nut and fit tighter up to the clutch hub. I had to go and buy one as I didn't have a 19 mm deep well last night but the deepwell impact socket worked on the first try. I thought I might have to grind the socket down a little but there was no need.
I didn't use an air gun, but I did have to use a big breaker bar to free the clutch. Alot of leverage for a darn little saw clutch but the usual tools just don't have enough leverage. I had to jam the flywheel with a screwdriver against the case instead of jamming the piston with a stop or a piece of rope.
