Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Rigging rings...pros/cons
  1. #1
    TreeHouser Sponsor treesmith's Avatar
    Join Date
    Feb 2009
    Alabama
    Age
    51
    Posts
    2,809
    Default Rigging rings...pros/cons
    I bought a set of the large rings last year, and spliced me up a set on a length of 3/4" Tenex Tec. I have used them a few times, and can tell a difference in the shock-loading of large pieces vs using a block. I know a lot of folks have gotten into using rings, and wondered if there is any drawback to them. I'm pondering getting another set (likely medium this time), and splicing a double set onto a whoopee sling. Here's the one I spliced up last year, along with the rigging thimble I spliced up.
    Any thoughts? Pros? Cons?
    "Honor is what no man can give you...and none can take away. Honor is a man's gift to himself."
    -Rob Roy McGregor
  2. #2
    Treehouser Sponsor Jonny's Avatar
    Join Date
    Sep 2018
    Buffalo, NY
    Posts
    496
    Default
    Got a single large ring on a whoopie and a small x ring on an ultrasling.
    Cons I guess would be not midline attachable, and they can get hotter than a block ever would. Haven't heard of them getting hot enough to damage the sling, but can glaze a rope. A little friction in the canopy is usually a good thing IMO. Means ultimately a little less friction on the lowering device. Of course a porty can also glaze a rope under the right conditions too. Blocks are better for lifting with GRCS or mini or whatever.
    Pros are weight, mass, cost, and not worrying about breaking it when I chuck it to the ground. Awesome piece of rigging gear.
  3. #3
    TreeHouser Mick!'s Avatar
    Join Date
    Nov 2013
    South West France
    Age
    55
    Posts
    8,903
    Default
    That sums it up for me Jonny, since I bought my big ring I haven’t used the block.
    Iím condescending, that means I talk down to people.
    Mick
  4. #4
    TreeHouser Sponsor cory's Avatar
    Join Date
    Aug 2008
    CT
    Age
    61
    Posts
    19,003
    Default
    Quote Originally Posted by Mick! View Post
    Same here. And I'm a huge fan of blocks and rope care. Pros are set-up speed, simplicity, pieces can frequently be run with no lowering/friction device compared to using a block. Con is slower rope retrieval time
    https://www.masterblasterhome.com/sh...-Rigging-rings
    Mastery is an illusion, grace a momentary gift, apprenticeship endless.
  5. #5
    Join Date
    Feb 2009
    Alabama
    Age
    51
    Posts
    2,809
    Default
    Thanks, Cory. I missed that thread. I am wishing I'd made it a whoopee instead, as it's slow to tie/untie every time it's moved when blocking down big wood.
    The rigging thimble did nicely the one time I've used it. We rigged down some 400#-500# red oak chunks, and it did well.
    -Rob Roy McGregor
  6. #6
    Join Date
    Aug 2008
    CT
    Age
    61
    Posts
    19,003
    Default
    Quote Originally Posted by treesmith View Post
    Yeah its interesting, when I used a block exclusively, it was on 12' of 3/4"tenex. To start a typical removal, I'd tie it high into approx 4" diameter wood, use it to take out all the brush and a lot of the wood and then retie it lower into thicker wood where the beefy and long tenex was perhaps a bit more needed. But once I started using the double ring on a short length of 3/4"double braid, I realized I was regularly and quickly girth hitching into that initial high tie-in point with the rings and the 12' length of tenex on the block was unneeded probably 85% of the time.
    Bottom line was faster installation on every movement.
    I'm ready and eager to use a block when it is called for but have been doing a lot of big removals since that earlier thread and haven't used the block since, for lowering.
  7. #7
    Monkey for Hire Sponsor biggun's Avatar
    Join Date
    Apr 2008
    Nesoddtangen, Norway.
    Age
    44
    Posts
    2,689
    Default
    I made this one up a few years ago along with a couple of cambium save type small ones.
    I rarely use them tbh and I like a Krab in the rigging line and it is a pain to untie some times.
    The one in the pic is two beast rings and an XL spacer.
    Attached Thumbnails Attached Thumbnails BFBF4D05-FC4C-4751-9CB8-27AC14E792EE.jpeg
    Rich.
  8. #8
    Join Date
    Aug 2008
    CT
    Age
    61
    Posts
    19,003
    Default
    Nice looking gear.
    Hey Rich, hows the martial training been going?
  9. #9
    TreeHouser Sponsor
    Join Date
    May 2013
    Posts
    467
    Default
    ... I am wishing I'd made it a whoopee instead, as it's slow to tie/untie every time it's moved when blocking down big wood.
    I am leery of the whoopee slings for heavy work. Yes I have a massive 1" whoopee, but a simple sling IMO is safer and stronger
  10. #10
    Join Date
    Feb 2009
    Alabama
    Age
    51
    Posts
    2,809
    Default
    Quote Originally Posted by frans View Post
    How so? How can a tied sling be stronger than a whoopee if it's the same material?
    -Rob Roy McGregor
